I know there is a service instruction that allows you to move the VR inside the cockpit, but if you haven't done that here is a way to help your VR temps.
I have seen RV12's that have the reg/rec. (voltage Reg) air hose up into the fresh air intake for the plenum. It barely protrudes into the side of the air intake tube. This design seems like it would cause a vacuum as the fast air moves past this small reg/rec tube. This would cause less air circulation delivered to the VR. I pushed the VR tube through the side of the fresh air tube farther and siliconed it facing forward into the positive pressure air stream. Dropped the temps by 20F on the reg/rec. The other heat sources is the air from the back of the cooler and the radiated heat from the #4 exhaust. Next I'll wrap that #4 pipe with some header wrap. This should stop convected heat and radiated heat on the VR. I would bet that this will bring the temps down under 140F or more. 170F is a VR and ignition module killer.
