"might work fine but why bother........or are you really needing that extra 0.1 of a knot? "
DB
Uh huh, @ 200mph a 1/4" round rod VHF whip generates about five lbs. of drag. Ballparking 1.5 lb thrust per HP that sounds like waste to me. Plus, I've seen lotsa whiskers get broke. Skins cracked under blades & towel bars, and I almost got my eye put out by a (^&&^ VOR once. Also, I thought Archer antennas wound up in the wingtips because That's where the fiberglass was on most planes. As for line of sight, the classic location on a spammer is the vertical tip. What's gonna block reception in the fiberglass roof? The prop, or my little pinhead?
