FAR Part 23 was rewritten a few years ago, but you can read the content of Part 23 before the rewrite (it was very prescriptive before) and it contains the information on how certain airspeeds should be determined for certification.Hi Avanza, thanks for your reply. My question is somewhat more in depth. I am asking how the actual numbers are determined/calculated - i.e. for an RV-7. According to the RV-7 POH, Vne is 200 kts IAS and Vno 167 kts IAS. How are these numbers calculated? I have read somewhere that when flying at Vno, the aircraft must withstand a gust load of 50 fps - i guess without esperience any structural deformations. Ref my initial question about g-loads, weights etc.
Thanks, I,ll look into that.FAR Part 23 was rewritten a few years ago, but you can read the content of Part 23 before the rewrite (it was very prescriptive before) and it contains the information on how certain airspeeds should be determined for certification.
The site I found with the Part 23 content can be found by clicking here and you want to look at Section 23.1505.
I think the answer to your question is beyond the scope of this forum. There are some good places to start, though. I like the “Aircraft Design” series of books by Lan & Roskam.Hi Avanza, thanks for your reply. My question is somewhat more in depth. I am asking how the actual numbers are determined/calculated - i.e. for an RV-7. According to the RV-7 POH, Vne is 200 kts IAS and Vno 167 kts IAS. How are these numbers calculated? I have read somewhere that when flying at Vno, the aircraft must withstand a gust load of 50 fps - i guess without esperience any structural deformations. Ref my initial question about g-loads, weights etc.
Note that Van's has changed the Vne definition from 200 KIAS/230 MPH IAS to 200 KTAS/230 MPH TAS, specifically to improve the airplane's flutter margins at higher altitudes. Unfortunately they never issued an SB or SL with this critical safety-of-flight information change, but they did update Section 15 of the builder's manual: https://www.vansaircraft.com/service-information-and-revisions/manual-section-15/Hi Avanza, thanks for your reply. My question is somewhat more in depth. I am asking how the actual numbers are determined/calculated - i.e. for an RV-7. According to the RV-7 POH, Vne is 200 kts IAS and Vno 167 kts IAS. How are these numbers calculated? I have read somewhere that when flying at Vno, the aircraft must withstand a gust load of 50 fps - i guess without esperience any structural deformations. Ref my initial question about g-loads, weights etc.
Hi RV8JD,Note that Van's has changed the Vne definition from 200 KIAS/230 MPH IAS to 200 KTAS/230 MPH TAS, specifically to improve the airplane's flutter margins at higher altitudes. Unfortunately they never issued an SB or SL with this critical safety-of-flight information change, but they did update Section 15 of the builder's manual: https://www.vansaircraft.com/service-information-and-revisions/manual-section-15/
Also, note that Van's Aircraft never issued a POH for the RV-7 since every RV-7 is different. And be skeptical of any POH you get off the internet, as many contain either errors or information specific to the builder's airplane.
Hi rocketman1988,I think the answer to your question is beyond the scope of this forum. There are some good places to start, though. I like the “Aircraft Design” series of books by Lan & Roskam.
