cardinalflier
I'm removing an older Vision 1000 from my RV-6 that I did not build. How do I remove the wire from the large sending units on the temp and pressure sending units so the wire will pass thru the firewall? I do not want to cut the wires in case anyone wants my used unit. Bruce Estes
