Ok, I've now flown N660RV for 1.6 hours. Initial squaks were taken care of but one persists. We had a vibration at high engine speeds. i.e. > 2400 RPM. We had the prop balanced and that helped. Now it's very smooth at 2400 RPM as long as I use the throttle to set the speed. If I open the throttle and use the prop pitch to get back to 2400 RPM the thing shakes like mad. BTW: This is an angle valve IO-540 with a McCauley three blade prop. Is it possible for the blades not to pitch at the same angle? I would have thought that there would be a geared system so that couldn't happen. Frustrated in NM.
