chuckwn
I discovered this mess during a regular 50 hour inspection. After some poking around, the source turned out to be a loose primer line. The fuel was turned black as it leaked by the flared tube and got spattered on the firewall.
The cause was a warn adel clamp that isolates the relative motion of the engine and firewall. The primer line was sliding back and forth in the adel clamp. This motion was applied directly to the attach point of the flared tube causing it to become leaky.
Be sure to check to check those clamps for security!
This installation has 1675 hours flight time.
![engleak.jpg](/proxy.php?image=http%3A%2F%2Fwww.fdatasystems.com%2Fchuck%2Fengleak.jpg&hash=978a73300c58fe42d71bc1970611bbb8)
