There are basically three vertical stab/rudder combinations used on the two-seat side by side models.
1. The original RV-6 short tail without a counterbalance that uses the folded trailing edge. Also known as "bent" trailing edge.
2. The early RV-7, short, counterbalanced rudder version with the folded trailing edge that is the rudder that came from the RV-8.
3. The large, tall, counterbalanced rudder version that uses the double-flush rivets at the trailing edge that is used on the RV-7 and RV-9.
I have never seen a RV-6 with the largest rudder. But there are RV-6s with the early RV-7/RV-8 vertical stab/rudder.
Also, there has been some concern from other posters here that......if your RV-6 already balances towards being tail heavy, that the bigger parts will throw your empty Center of Gravity even farther aft.
It seems if you want the taller vertical stab/rudder then you need to be looking for the RV-8 parts.
