I started to look closer at the vertical stab. tonight and noticed some issues:
https://www.dropbox.com/s/xey9jx7ipgn3nr0/Rear Spar Attach.jpg
As seen in the picture, the rear spar is pretty banged up for some reason unknown to me. A section at the bottom has been broken off and some holes are elongated, etc. I am tempted to order in new rear spar material and remove the old one, etc. Any thoughts on what might have caused this kind of outcome?
https://www.dropbox.com/s/5lix94icfcfps1r/VS front Spar attachment.jpg
https://www.dropbox.com/s/xuoiufyp96ivo7m/VS front side view.jpg
As seen, the front spar attach bracket is pop riveted onto the VS front spar (VS-2), and the material is really thin. Drawing 16 & 26 of my "preview" plans isn't much help in determining if this is the correct part, as far as rivet call out, or thickness of material. Can anyone tell me if the "real" plans provide anymore detail? I know my 9A attach bracket is quite a bit thicker than this one.
Thanks for any ideas...info.
Doug Lomheim
RV-3 Restoration
Doug Lomheim
RV-3 Restoration
