Instructions say that when mounting the vertical stabilizer, you should measure from the stabilizer to the horizontal stab edges and the measurements should be the same to ensure the stabilizer is vertical. I'm probably overthinking this, but the front edge of the vertical stab is off to one side about 1/4". If the measurements I take are equal, doesn't that mean that it's NOT vertical? Do I just measure close to the middle of the top of the vertical stab, add the offset amount, and have that number be equal? That's what makes sense in my head, but before I drill holes that can't be undone, figured I'd ask.
