Vertical Stab Lightening holes
Although it doesn't save a lot of weight, lighten everything you can. "Build lightness in" as Van's would say.
That's how I got my empty weight down to 990 lbs for its first flight.
Done in the newer kits already
My 9 tail kit had the VS spar doubler already "lightened".
Caution
Be sure to cut holes ONLY in the thick spar NOT in the thinner material. I made the mistake of cutting through both and thought it would not matter Vans said it MUST be replaced. Simple case of not paying close enough attention. ::eek:
