Steve, Did you talk to Van's?
The omission to final drill the holes needs to be corrected. The bolts are a very tight fit in the holes without the final drill to #12, and the nutplate will have to be exactly lined up with the hole or you would not be able to start the bolt, at least not without possiblity of damaging the threads in the nutplates. The bottom MS21051-L3 nutplates are even more problematical, because the rivet holes are so close together you can not use a cleco in one of them when you set a rivet. At least I couldn't. I started an AN-3 bolt about 3 threads into the nutplate to align it exactly with the hole, used a cleco clamp clear of the rivet to be set, and got it done. I think it would be a good idea to check the fit of the F-1210B plate to these four nutplates by putting the plate in place and screwing in four AN-3 bolts fingertight 3 threads though the plate just to be sure you will be able to bolt the vertical stab to the fuselage without a problem later. The two bottom nutplates can be easily replaced but the two upper ones in VS-1202 can't be replaced later without taking out a bunch of skin rivets. Reference: P. 06-05, Fig. 2 and for the F-1210B look at P. 10-02. And the plans do say to final drill the F-1210B holes to #12.
Tony
