b17fe
I'm looking for a picture of the bottom of the vertical stabilizer fuse connection on an 8.
When lining up the locating hole and the 812b angle\control stop (neither drilled
in my -1 kit) the bottom of the vert. stab. is about 1/8" up from the tail spring
mount cut out.
My thought is that it should be lower to ensure the top 2 of 3 bolts hit the aft tail spring mount correctly.
How did yours line up?
Thanks !
mount cut out.
Thanks !
