Vent fitting at fuel tank
wings05rv6a
Active Member
Hello everyone HAPPY HOLIDAYS!!!!
I need HELP. I am in the process of final assembly. While instaling the vent tube from the fuel tank to the fuse I noticed that the fitting at the tank started to rotate and the proseal had been broken. The tank is painted and the attached to the wing. What is the best way to repair this? :confused:
Bob Wieczorek
Not too sure if the 6 is plumbed like my 10, but I expect it is.
I had a similar issue, ended up removing the sender/float mounting plate, and working through it, then replaced the plate.
Worked for me.
