I forgot to drill the vent-clip hole to 7/16" in order for it to receive a snap bushing. (I could mention that the plans neglect to tell me to do so, but that would be wasting time and whining so I won't mention it). I can still drill it to size with my angle drill, however, that's a bad idea. In the RV-10, the clips are cut from several lengths of identical stiffeners all but two of which are unneeded. I took a discarded clip and drilled it to size to see what it would look like. The images speak for themselves.
The hole isn't centered well in one side of each clip because I trimmed wide, not understanding these holes would be enlarged. Depending on how I oriented the clip in the tank, the little hole might be centered or it may be off (the images will illustrate). it's a 50/50 shot. One tank has the UNfavorable orientation. Not sure about the other yet. I'd really rather not drill this out given all the proseal.
So here's my question. I'm thinking I'll drill out to 9/32" which will leave lots of edge regardless instead of 7/16" and NOT use a snap bushing. Rather, I'll set the vent tube in place, get it torqued properly to the inboard rib and then gob up some proseal around the vent tube where it passes through the clip. This should keep it from vibrating and possibly cracking, I would think. What do you think?
Figure 1: Vent clip all nice and prosealed in place with nice small hole.
Figure 2: What the vent clip should look like (side A of clip):
Figure 3: What vent clip might look like (side B of same clip)
