If you go to Van's website and search on wing wiring, you will find a pdf document with their guidance for enlarging the wing tooling and wiring holes.
Excerpt from Vans documentation:
1. The tooling holes in the ribs may be drilled to a maximum of 5/8? and plastic Bushings SB625-7 installed. These bushings have a 7/16? inside diameter and should be adequate for most needs. Of course smaller bushings can also be used.
2. An additional hole may be drilled in the lower 1/3 of the rib between the large lightening hole and the next one aft. This hole may be up to 3/4? diameter to accommodate our wiring conduit (DUCT NT 5/8-50) or Bushing SB750-10 (5/8? I.D.). The conduit is light and flexible. It?s .810 ? outside diameter means that when snapped into place, the corrugations hold it from
slipping out. If using the conduit, a dab of fuel tank sealant or RTV should be put on the conduit at each rib to prevent the conduit from being cut through over time from vibrations.
3. You can drill a small hole, #30 will do, near the edge of each lightening hole in the rib and use a cable tie to tie either wire or conduit in place. Be sure to protect the wire from chafing on the lightening holes.
I found the wing walk ribs the most difficult place to route the conduit. I think I may have enlarged an additional 1/32" in this area.
Mike Andresen
www.azcloudflyer.com
Working on finish kit.
