Good morning!
I'm hoping there is someone out there who has NOT installed a Dynon heated pitot but instead used the supplied aluminum cheapo as I am. My question is, Where is a good place to change from the aluminum tube to a vinyl one? I'm prearing for wing fitting and the plans only say to drill a hole in the fuse skin for the pitot. I have the aluminum tube coming out of wing and not sure if I should bend it to line up between the spar and the aileron push tube hole or cut it off short and attach a flexable line. I couldnt find any posts on this. I'd like to have an idea of where best to run the line once thru the fuse skin too.
Thanks in advance for any input..
Bill
Bill
