Cth6
* Pending payment / pickup *
I am replacing my Vans Aircraft (ISSPro) logo’ed 2¼” engine gauges as well as a few EI gauges in my RV-9A. These are mainly from the panel. I am looking for $30 a gauge (+shipping from Central FL). The last ones I shipped ranged $5-9 in the US. Validated these all work as of this morning when I removed them from the aircraft.
If you are looking for a complete set of Vans gauges, I will sell them together as a package for $225 + shipping.
Happy to facetime or if you are in the area and want to pick them up in person.
- VMP35 Manifold Pressure Gauge with VMPSND
- VFP15 Fuel Pressure Gauge w/ sender
- VOP100 Oil Pressure Gauge w/sender
- VOT250 Oil Temperature Gauge w/sender
- VFL15 Fuel Gauge x2
- VV16 Voltmeter Gauge
- VTAVH3500 Tachometer Gauge with cable and sender
- VTAVH3500 Tachometer Gauge with cable / No Sender. (Will throw this in as a spare if you buy all of the Vans Gauges.
- UBG-16, set up as 4 Cyl EGT/CHT, Oil Temp and OAT. The last digit on the far right bottom, does not show the bottom bar for a minute or two after starting. Once warm, it lights up as expected. An “8” will look like an “A”. So if your CHT is 188 you will see 18A. Selling for $150 without probes.
- VA-1A, with the built in shunt. $150
- FL-2CA, Dual Fuel Level (Capacitive) $100
