Does anyone have the measurements of vans green throttle/mixture cables With a section of the gren plastic removed??
I think the unaltered diameter is around 0.335.
I have gotten frustrated with trying to get stel eyeball grommets for them and have nearly decided to return them all and go with simple firewall shields over vans grommets-cheaper too!
I bought the steel gromets in .125 size thinking they could be drilled up. They can but only to .260
Purchased the .260 size thinking they could be drilled up to .335. They cant. They are at max drill already-basicly the .125 hole eyeball just drilled to max for you.
Next size is .35 which is too big.
So...Is bare cable under the protective green sheath gonna work tight with the .260 eyeball?
Is it ok to remove some of the sheath or is that a bad idea?
Thankyou..
Thankyou..
