First off, thank you all who have been supporting us over the years and adding your valuable input. We are now officially working with 11 OEM aircraft manufacturers and are endorsed and trusted by their own independent R & D testing departments! Thank you!
As this market is relatively new, there is some gray areas that we want your input with.
We would like to ask all of your for your input about the specs for a lithium iron phosphate battery. It can replace a lead acid battery, but it is not the same. To date, we have tried to write up the spec's in a comparison type language but maybe it's time to revolutionize this area.
A lead acid battery open circuit voltage (OCV) is technically 12.6V. (definition of an OCV is: Open circuit voltage (or potential) is voltage which is not connected to any load in a circuit) but we call it a 12V.
A lithium iron phosphate battery OCV is technically a 13.2V but the industry calls it a 12V so that people know they can use it as a replacement.
We are considering changing how the industry labels the batteries, or at least our batteries, and want to call the voltage 13.2V but we are afraid consumers will think they can not use it as a replacement for a 12v battery. Any thoughts?
Second question, any input on how to label the amp hours? This is an area that is all over the charts from battery manufacturer to battery manufacturer. (and marketing material as well) We want to state exactly how much amperage you have in the event you are using the battery as a deep cycle application such as when your alternator fails. We list both now, what type of equivalent amperage a lead acid battery would have for the amount of cranking power and the usable amp hour. We want to go to listing only the usable amperage but the numbers of what a lead acid might say will look much more in comparison even though it might be less as very few will list the true usable amperage. As an example, if we list the ETX680 as 12.4ah, and the PC680 list theirs as 16, but only have 12.3 usable for an hour) it is confusing. And if you compared another lead acid manufacturer, their listed 18 amp hour might only be 10 usable by design.
Look forward to hearing your input and thank you in advance!
Kathy
www.earthxmotorsports.com
Thanks Vans Forum users
Kathy
