Van's Flight Com wiring Harness
apkp777
Help - I powered up my electrical system. All systems good except for my intercom. I have a Van's wiring harness for my flight com. There are 2 wires that are unconnected. RZ12 and RZ 14. Anyone know where they go? I am getting headphone, but no side-tone and I need to check the mic yet.
I should have gotten a Stein harness. The Van's harness install install doesn't jive with the flightcom install diagram.
I've used the Van's harness and flight com intercom 3 times now. Use the Van's drawing and Van's install instructions and you will have no problems.
The only way I can see this getting screwed up, is if you bought the harness and used the flight com instructions instead of the Van's instructions.
I don't even look at the FlightCom instructions!
Regards,
I just figured out that the squelch on my SL 30 was set wrong. It appears that all systems are go!
Thanks!
