Hi all, busy doing some work on a flying 10. Purchased the PlaneAround door pin kit. It says that the Vans supplied magnets should drop into the pins. The magnets we found in the door tubes does not fit into the pins. I assume the magnets are not those supplied by Vans? Any ideas? Thank you
