Vans 90 Degree Oil Filter Adapter / B&C SD20
n4322b
Active Member
Patron
Hi
I'm thinking of fitting a B&C Sd20 standby alternator. I already have a Vans 90 Degree Oil filter adapter. Does anyone know if the two clear each other please ?
I saw another post from the RV10 guys where he was having problems with the B&C oil filter adapter.
Ian
On an RV-10, for the B&C oil filter adapter there?s a requirement for a spacer to clear the engine mount. When combining this with an SD-20 there?s a spacer kit (includes a replacement shear coupling) to move it back also to clear the filter adapter. Can?t help you with what happens with other brand filter adapters.
