Someplace I saw a short hose designed to screw onto your tire valve stem.
Allowing you to check tire pressure without removing wheel fairings.
But now that I want to buy one, I can't find them.
Can anyone help?
is great to keep in the hangar. Just use a band saw or cutoff wheel to remover the lock & it will go straight into the hole in your wheel pant. (edit: 'calibrate' the gauge on it to a known-good gauge; mine was about 10 lbs off.)
I have a couple of those auto parts valve extensions that I keep in the airplane tool kit in the event I need to fill up on the road. The ones I have screw into each other so a couple of the short stubbies is just right.
