VA-146 Bearing not centering
wizard
Active Member
Emp kit arrives and after only a days work, I already have a question. Good things you guys are here. With the HS-411 brackets clecoed in place and the holes in VA-146 and the pre-drilled HS-411 lining up, the bearing is not exactly centered in the non-pre-drilled HS-411. Can I assumed that this is why one of the brackets is not pre-drilled or should the bearing be exactly centered?
Get everything all in place with clecoes and bolts and match drill as directed. It will be fine.
Roberta
