VA-13 and FF-00019 Torque Value
NZ_Pompey
Member
I'm trying to find the appropriate torque values for these 2 fuel hoses from the firewall to the iS engine connections, but have so far found 2 different tables, both with different values.
Does any know a definitive source for these, or can confirm the correct torque?
[edit - should read VA-138]
Thanks!
Paul
Vans Torque_Spec_Aluminum_Fittings.pdf
Thanks!
Paul
Check your PMs
