wawrzynskivp
Hello All,
In another forum the discussion of swapping out safety wires with Nord Lock washers was covered. If acceptable it seemed a seamless swap, but there is a difference.
We know that the choice of using a friction nut (example: nyloc) will increase the required torque to achieve the design bolt tension for any particular fastener compared to a standard nut. (Friction nuts have their own friction to overcome)
Nord Locks have their own friction too.
Using our standard torque values on a Nord Lock will result in up to 20% less fastener preload. Nord Loc offers this may be acceptable, but it's up to us to decide if that is the kind of work we want to do. If you want design preload or bolt tension you need another torque value when adding Nord Locks.
Consider Nord Locks to be friction washers (yes, yes, Nord calls them tension lockers). Just like friction nuts, friction washers require additional torque to achieve design bolt tension:
https://www.nord-lock.com/insights/...i-change-my-tightening-torque-with-nord-lock/
