Anyone using Bluetooth to capture cockpit audio with a GoPro?
I've been using an old Hero 3 for making videos in the cockpit. For audio, I simply plugged the portable intercom output into the camera. Worked great but it was yet another wire cluttering up the cockpit.
Recently I upgraded to a Garmin GMA 345 Audio Panel with a built in intercom and Bluetooth. I now have no wired audio out to plug into the camera.
I see that Spruce sells a splitter cable that plugs into your headset which should do the trick but still...more wires.
I would like to be able to use the Bluetooth output from the audio panel and pair it with the camera. However, I don't believe GoPro has that capability.
Anyone know how to do this?
Thanks...Peter
Thanks...Peter
