Vans has a recommendation that 2 1/8 in PVC pipe spacers can be bolted between the ring gear and the spinner back plate to get the proper spinner position when fitting the cowl. This should allow this to be done without having the prop mounted. Has anyone had problems doing this? I worry that when the prop eventually goes on the clearance between the front of cowl and spinner might not be right and options at that point may be limited.
