Sam Staton
I would like to install built-in USB jacks into my panel to support my iPad & my iPhone. I have obtained stand-alone USB jacks, but I have found an issue with Apple's implimentation of the USB standard for charging. Apparently, unless there is a certain voltage present on the two data wires, the devices will not charge. Does anyone on the forum have any info on this? I believe that if I can determine what the voltages need to be, I can design a circuit board to present the proper voltages. Thanks in advance!
