The 6's wing is just fine for speed and economy. I have a 160hp O-320 and have seen as much as ~ 200 mph (174 knots) true airspeed in level cruise at 7500-8500 MSL burning 8.9 gallons per hour. This was with a full load of camping gear in the baggage area too. When I'm just out flying around for fun, I throttle back to about 2100-2200 rpm and still go 140-150 mph on 5.3 GPH.
The original stock, short -6 rudder is also a good one too. It's not counterbalanced, but doesn't need to be either. There is no danger of flutter at the published Vne with this stock rudder.
The reasoning behind using the larger rudders (RV-8 at first, then finally the late RV-7/RV-9 rudder) on the -6 was to help with spin recovery. You do not want to intentionally spin a -6. It is capable of spin recovery with the original small rudder, but the spin develops very quickly and will take much longer to recover with full recovery control inputs than what a "regular spamcan" trainer airplane will do. In other words, spinning a -6 will probably scare the holy crapola out of you and might make you panic (and if you don't have enough altitude, then you know what happens next). The larger vertical stabilizer/rudder of the early RV-7 (which is actually an RV-8's VS/rudder) or the later RV-7 (actually the RV-9's VS/rudder) have both been used on RV-6s and both help with spin recovery, the larger late RV-7/RV-9 rudder being the most effective..... BUT, both weigh more than the original short tail, and if you've got an O-320 with fixed pitch wood prop on an RV-6, you may have some aft-CG issues, which is not good for spin recovery either. Both of the larger VS/rudder options also have more drag, which results in a lower top speed too. Many folks think the taller tails don't look as aesthetically pleasing on the RV-6 either. It's all a series of compromises and trade-offs. Here's Van's service bulletin about spinning a -6 or -7:
http://www.vansaircraft.com/pdf/sb02-6-1.pdf
As for my personal opinion, I prefer the smaller tail on my RV-6. It looks better, has the least drag, and I don't intend to intentionally spin this aircraft. It does however require a lot more right-foot pedal on takeoff and climb, and needs some left-foot pedal on descents, to center the ball, but that's what developing good "stick and rudder" habits is supposed to be all about, correct? After flying a Piper Cherokee for a decade (which has rudder pedals just so you can steer the nosewheel while taxiing) flying the RV-6 is like learning how to fly an airplane all over again
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
