Reading the RV-12 POH, it specifies up to 4 gallons of unusable fuel depending on aircraft orientations like level flight or climb, etc.
Given this, what fuel minimum is everyone using to comply with the VFR reserve?
I've been looking at flying in a -12, but given passenger and baggage weights would be limited to about 15 gallons to not exceed the 1320 lb. GW, so the unusable fuel would make for short durations at ~5 GPH for flight planning, if accurate.
