Unusable Fuel for RV-10
rvanstory
Sponsor
Ready to do a fuel flow test on my RV-10. According to EAA webinar, for kits that have already had unusable fuel test run at decent and takeoff/go-around attitudes, you only need to do the level flight flow test. Since the unusable answer will be the same for all kits that were built per plans. https://www.eaa.org/videos/2195707082001
So, does anyone have this data on the RV-10? Would really like to avoid jacking up nose to 25 degree attitude if the answer is already available.
Not all fuel systems will perform the same. I would suggest you do the test on YOUR plane to get those numbers. It really is not hard to do.
