Michael Burbidge
I adjusted the outer flange of F-631A. After doing so it has a wicked twist. Both inside ends have twisted up about 1/2 inch when the part is laid flat on a table. The outside edge is close to flat its entire length. I've puzzled over this for some time and cannot envision where to flute to remove the twist while still maintaining a flat outside edge.
How did you go about fluting this? Where did you flute? e.g inside-middle, outside-end, etc.
Here's a couple of pictures.
Thanks for the help,
Michael-
Michael-
