Unstable tachometer
After about three hours of flight time my Skyview tachometer has started to bounce around when over about 4000 rpm. The engine sounds fine but Skyview warning drowns out everything. A loose connection could be the culprit but why only when over 4000 rpm?
Henry
I had the same issue. Dynon said double the prescribed resistor on the tach pick up line. I did that and the problem went away.
