Unleaded Avgas - Thoughts?
That is incorrect. Lead is an abrasive. In no way is lead a lubricant.
Especially in the chemical structure as the result of burning TEL in our engines.
Tim
Tim
Actually, Lycoming recommends LW-16702 in the oil regardless of which fuel you use. Note that Aeroshell includes this in some of their oils such as W100+ and 15W-50.
Skylor
Tim
Lead (tetraethyl lead) in 100LL fuel acts as a cushion and lubricant for valve seats during engine break-in. The lead byproducts coat the valve stems and seats, enhancing sealing and providing protection against valve seat recession and wear. So maybe not as a general lubricant, but it does help during breakin - at least this is what I was told, and why it was recommended to not use UL94 during break in.
I would want to see some recent data to back that up. Lycoming and CMI have used hardened valves for decades.
Tim
Skylor
LW-16702 is just their version of Camguard, isn't it?
If you fly regularly, like once a week, this is not needed at all. If the airplane routinely sits still for 30+ days, then by all means...
Tim
Lead is far more like a lubricant than an abrasive. I challenge you to use a lead bar to scuff up your paint or abrade anything else for that matter. While itmay not technically be a lubricant, it provides similar properties in many applications. It is used to coat metal parts that interface with other metal parts to prevent wear of those parts. Heck, my old lathe has a small lead storage device, as lead was put on the dead spindle as a lubricant. Back in the days before hardened valves, the lead in gasoline was critical to prevent the valves and seats from wearing. Replace that lead with valve lapping compound, an actual abrasive and you start removing metal fast.
I also reached out to Lycoming Technical Support to get their opinion and this is what I got back: "UL94 fuel would be acceptable for use in a IO-540-C4B5.
I recently called into the Ask the A&P's podcast and spoke with Mike Busch and his crew and I asked them the question about UL94 with this kind of an engine. You can listen to the podcast for his full answer (it should be getting released soon) but the net of it is that he suggested backing off the timing by 3-4 degrees if I want to exclusively use UL94. My plan (hope?) is to be able to run up to 50% UL94 so I will start playing around with the timing once the break-in is done.
What did Lycoming say about backing off on timing when using UL94? Not sure I would go on Mike Busch recommendation alone especially considering Lycoming support has taken a position on UL94 so they must have done some engineering or testing.
That article is from 2008, and and references data from the 1960s, with an anecdotal reference to engines overhauled 15 years ago. Which means those engines had been purchased likely decades ago.
E.g. this data is very old. Find something much more current.
Also, check the break in directions from Lycoming and CMI on engines they produce which accept 94UL. You will find no reference to adding leaded avgas.
Tim
Lead by itself, maybe. In an avgas engine it is not. Check https://en.wikipedia.org/wiki/Tetraethyllead
Look at the byproducts Lead chromide and lead bromide.
Then web search what these byproducts are used for.
TEL is an antiknock agent used to cool the flame front and increase the octane rating. Nothing more, nothing less.
Tim
You can do the research yourself and this being experimental …you have my full support. In the forum you can find the cure to morning sickness, once you start having valve sticking issues and the fix is a Lycoming service bulletin, you can do yo;itself.
I was simply responding that lead is not an abrasive, as used in fuel, or industry…however…if you think the engines have changed compositionally since 2008, you’d be wrong. Metallurgically speaking they are the same as in the 80’s…the notable exception being DLC coating for the lifter faces.
The beauty of experimental aviation is that you are free to conduct your own experiments, with your own pocketbook and backside. Beyond that…the notion that the minuscule amount to lead burned in GA in total, isn’t even worth consideration in the big picture, environmentally speaking and despite alternative fuels being around since the 70’s none have really taken hold and worked out,
Tim
Your original statement above. This is simply not correct as other have stated. Lead and other soft metals (more commonly copper and tin in my experience with industrial gas turbines) are commonly used as lubricants and/or sacrificial lubricants. Branching or expanding a position to include combustion effects doesn't change your initial statement.
Edit = anyone else remember all of the engine life issues when the car industry switched to unleaded fuels?
Edit = anyone else remember all of the engine life issues when that industry switched to unleaded fuels?
Yes, I mentioned that. The lead was used to protect the valve and seat faces from wear. Lead went away and problems appeared. The industry then moved to hardened metal valves and seats to deal with it.
And let’s remember…those are water cooled engines. air cooled engines by nature have a different set of variables, thermodynamically….somwe know that lead has primary and secondary functions in our engines…
And yes…I was just taking exception to the statement that lead is an abrasive in fuel…which is incorrect.
I didn't ask them that question. All they said was that the engine with 8.5:1 compression pistons is approved to run UL94. Trying to get them to comment on the timing may be a challenge because in a podcast where Mike Busch interviewed George Braly, one piece of information that George shared (in the context of moving to unleaded fuel) is that changing the timing on a certified aircraft requires a change to the type certificate.
Octane rating/detonation margin with nameplate advance and 8.5-1 pistons was never really a hurdle for UL94 IIRC. Many such power plants were STC’d for 91 octane car gas (Peterson’s?). This question (mine) and other’s opinions are of limited to no value. As mentioned by others, the only real position is the OEM’s.
Hi All -
I have a follow up to my previous video in February with some new learnings on hoses and bladders. I keep saying that I'm going to make the videos shorter, but there's so much information to cover.
Also, of note at the end of the video is that I have two speaking slots scheduled at airventure on the unleaded fuel topic (Monday and Thursday).
Michael
Hi All -
Michael
This is the most comprehensive real world testing of alternate unleaded fuels I have seen to date!
So glad that I stumbled upon your video series! You have taken the analysis to the next level, and presented the information in a very logical and understandable way.
Bravo Michael! Bravo!
It sounds clear from this and previous videos that G100UL is hopelessly DOA. Intrigued about Swift 100R and VP UL100E..
Yep. These tests and videos make the lone, poorly done, 2-year-old video at the GAMI site (with snide commentary) look like a middle school science project by comparison. (And why did they never post the "before" pictures, as they stated they would? Hmmmm...inquiring minds want to know!).
So much secrecy, as well...
After this series of well planned and executed tests, and their very negative results across the board for G100UL, I just can't see anyone putting this stuff in their plane willingly.
I agree. This is really excellent work, carefully controlled and documented. Kudos, and a big debt of gratitude, I'm sure, from a lot of people who might have tried G100UL and only too late found out that it strips paint, swells o-rings, damages fuel bladders, and all sorts of other mischief (some of which could be safety of flight issues).
I noticed this video there was no mention of UL94, this is what we have at San Martin, but I’m hopeful for a long term stable 100UL
I don't doubt that G100UL would work great in the engine as a replacement for 100LL. George is a very smart guy. However, the "incidentals" like the effects on paint, o-rings and tank sealants seem to be an afterthought. After building my fuel tanks, if there is even a 1% chance that the fuel I use would damage the tank sealant, there is no way I'm using it. No way I'm risking my new paint job with it either.
At this point, I think George needs to hire an independent lab to duplicate the tests @mluvara is doing and have the lab publish the results. I don't see much of a way forward otherwise.
Hi George,
I covered UL94 in a previous video when I tested it along side 100R. Since Swift has sold several million gallons of the fuel (and I'm unaware of any material compatibility issues nor did I identify any), and the fact that they intend to replace it with 100R, I did not pursue further materials tests.
Hi George,
I do remember the previous videos, thanks for clarifying it and looking forward to using 100R in the future. Is there any meaningful availability of it at any of the Bay Area airports?
+1, and same experience.
As already shared a few times here, my airplane was built, and modified to use Mogas (automobile gasoline, including some ethanol which I experience in northern countries around here). These mods, used on 2 carbed O-360s, include a T downline of the EDP with a return line to the selected tank (dual control fuel valve), replacement of all pressurised 90° fittings with 45°s, heat shields on the EDP and protecting the hoses.
Looking at the freedoms the E/AB category offers, I'm surprised how few take advantage of running cheaper and cleaner fuel... old wives tales, lemmings instinct, fear of new, or just ear-say speculations?
The design of the Lyco flat four is short of 100 year old, and still owes more to the agricultural equipment of the time than a modern racing machine...
EDP ?
From what I understand, they will start rolling out 100R to replace all the UL94 locations once the next step of the STC process achieves the expanded AML. Right now, it appears they have engines to cover what UL94 was approved for and are currently waiting on airframe approvals.
Hi all,
I was given the unique opportunity to test VP/LyondellBasell's UL100E unleaded avgas, and thus I have now compared all three unleaded candidates for a series of the same materials compatibility. Here is more data for your consideration, including a new learning about bladder cavity tape. Oh, and I have now done a little testing on the highly requested polysulfide sealant...
So, if you're currently waiting for the smoke to clear to get into OSH, this might occupy about 20 minutes of your anxious wait.
I'm scheduled to talk at AirVenture on Monday July 20th and Thursday July 23rd.
Michael
