As already mentioned, yaw trim will only be correct for one condition (airspeed, power setting, etc.) anything that changes you away from that condition (slowing to or below Vfe, etc.). With an off set vertical stab, it is normal to need to use some left rudder in a high speed power off decent.
See if the trim is off the same amount at the flap speed but with the flaps up.
Also check the influence of power on vs power off.
The main thing to keep in mind is that unless you have an in flight adjustable rudder trim, you will always have flight conditions where yaw trim is not exactly balanced. Most people adjust for the cruise condition they will be in most of the time and then not worry about the rest.
