U-805-1 Outboard GEAR Wear Plate
After positioning the gear legs properly per the construction manual, the proximity of the drilled hole of the forward AN4 Bolt that attaches the U-805 Outboard Gear Wear Plate has resulted in a clearance issue with a shop-head rivet on the F-843 longeron...., the drilled hole does not allow adequate clearance for the washer or nut to seat flush on the bolt, approximately 25% of the rivet shop-head interferes with the washer/nut ......
Has anyone had experienced this?
Any suggestions or thoughts would be appreciated.
Thanks in advance!
Mike Perillo
RV8 QB
Thanks in advance!
Mike Perillo
RV8 QB
