Seems like I remember this part being pre-bent, maybe .040 or .063 thickness. I can check when I get to the airport later today. Then you will need to bend the upper portion to fit flat against the lower gusset on the engine/nose gear mount (not sure if this bend was pre-bent). I recommend not drilling the two holes in that bent part per drawings 3/4" apart. (see DWG 45, EXIT AIR ATTACH BRACKETS). This is a custom fit, so you will need to drill in place, taking into account the positions of those two bolts with regards to the nose gear mount to assure you are able to get a wrench up in there to work with them and have proper edge distances on the gusset and this piece - tight area to work in for sure, but it can be done. Hope this will help. It's hard to describe in words.
