Phil
Just a heads up for those of you who are getting into the landing gear section.
On page 46-3, Van's suggest positioning the valve stem closest to the the red-dot on the tire. I did this and assumed Vans was correct.
Then I bought a tire/wheel balancer and thought I'd give them a peek to see how close they were. To my surprise they were way way out of balance. I attempted to balance the wheel and stacked all the weight I could onto the wheel before running out of space and the wheel still wasn't close. (That's 3.5oz for those counting.)
Common sense said something wasn't right so I dug out the old A&P manuals. Sure enough the red dot is the lightest part of the tire and the drilled valve stem is the lightest part of the wheel. You should install the valve stem 'opposite' the red dot so the two can counterbalance each other. Vans plans have you aligning them and creating the maximum out-of-balance scenario.
So I flipped mine around 180 degrees to see what would happen and validate the data point. I went from 3.5oz and still severely out of balance to .75oz and perfect.
So if you've got the plans in front of you, you should modify the plans to reflect positioning the valve stem opposite the red dot. If you've got an A&P book in front of you take a quick walk through it and you'll see the discrepancy too.
Phil
Phil
