Two things in same hole
yankee-flyer
On page 32-11 I'm supposed to secure the forward end of the rudder cable plastic sleeve to the inboard angle rib with an Adel clamp and an AN-3 bolt through a 3/16 hole. But back on Page 31-11 I was told to use an 6-32 screw and nut to ground the pilot's PTT wires ( the PTT wires and power socket on the right side) through that exact same hole. Getting thet screws out will be a bear with the sticks and pushrods all in place. Did everyone who already passed that place move the ground to another hole or ground the PTT's through the bolt that holds the Adel clam?
THANKS
Wayne 120241
Spotted the same problem. I used the Adel clamp hardware to attach the ground wires...
