Two GPS Antennas?
myrv
I'm New Here
If I want to install a second GPS antenna to connect my handheld GPSMAP 396 to is it going to interfere with the primary antenna? I assume the two devices can't share an antenna.
performance will degrade with 2 antennaes right next to each other. I had 3 small trimbles on my glare shield and had to move my primary(430) under the cowl to get acceptable reception.
Ok, so I have a Grand Rapids EFIS GPS antenna, an XM weather antenna, a Garmin 296 GPS antenna and a Sony XM radio antenna. How can I not put these near each other? :confused:
Ben
There is a combination antenna from Comant that has XM, GPS, etc all in one. Pretty pricy at $700 I think.
I don't understand the physics behind what is being described here. How exactly does a passive (i.e. non-transmitting) GPS antenna interfere with another GPS antenna, as long as they're not physically overlapping or blocking one anothers' view of the satellites?
Im with you Paul. I plan to line up all four in a row across my glareshield. As long as they have a clear view of the sky, they cannot interfere with each other -- that I know of.
Ben
Good question
I was curious about that, too. Perhaps it's the local oscillator leaking out of one antenna and being picked up by another? No receiver is truly passive if it has a local oscillator.
It's just fractions of a mW, but the GPS sats don't put out much power, either...doesn't take much to saturate the "neighbour" receiver's front end.
Another (half-baked) theory is that many GPS receivers use active antennas...there's an amplifier at the antenna. So the potential for interferences is -- at least theoretically -- present.
Any RF gurus here?
I have 2 BMA EFIS, each with a GPS. The BMA guys said I can mount them right next to each other without any problems. They look like the little Garmin antennas.
I can tell you it is a fact. With each unit I turn on, I can watch the signal level degrate on the sat strength page. Dont know why, buy it does. To the point that with 3 right next to each other, and in IMC, I have lost the 430. Thats why I moved it.
Best,
