ONE: In reviewing a data download, I noticed that my fuel pressure seems quite low in flight. I normally only look at FP at pre-takeoff and see it north of the minimum. In flight I had 2.5 to a little less than 1 PSI. It got my attention when I got a low pressure alarm during climbout. Fuel flow was fine. Could this be vapor lock? OAT was only 60F at altitude.
After reading applicable forum threads, I have drilled two more holes in the fuel cap, checked connections to FP sensor and attached an additional ground to the sensor case.
Subsequent startup and ground run showed 2.6-2.7 PSI anywhere from idle to 4,000 RPM. Pulling the boost fuse dropped it to 2.3. Did not fly yet as I want to connect up an external fuel pressure gauge tomorrow. Will hook this up in place of the sensor for ground test purposes. With engine off and boost on, flow out of gascolator is strong. I'm thinking this is some kind of sensor or calibration problem...
TWO: Fuel shutoff valve will not close completely. Yes, I have a steady dribble at the gascolator. Tried cleaning out by cycling valve with boost on. No joy. Valve handle clears floor with ease; no obstructions. Ideas?
Jim in South Texas
#264
Jim in South Texas
#264
