TT Gemini PFD Altitiude Resolution IFR?
Daniel S.
Just a random question from the peanut gallery.... Has anyone out there (who has a TT Gemini PFD) gotten a full IFR pitot / static check done? Well, according to the specs / regs in regards to experimentals. My question is did the Gemini honestly pass the altimeter check at +/- 75 feet? I know a lot of "non-TSO'd" altemeters out there will not give you proper altitude resolution for IFR flight, hence not being visable during IFR ops /and or placarded as such. I emailed TT a while and didn't hear back. They must be be busy cranking out that PFD/AP :D I know, I know I'm a long ways away, but just being and staying up to date with whats out there and on the horizon. I want to budget in TSO'd back ups if necessary to suite my own tastes.
As always, Thanks for the info.
My last IFR static/altimeter/xponder check my Dynon was dead on with minimal instrument error on the altimeter.
I did not have the Gemini PFD installed at that time but I can tell you that I have sucked a vacuum on my static system and compared the Gemini with the Dynon and they are pretty close to each other up as far as I felt like sucking on the tube.
I doubt you will find a modern experimental EFIS or EFIS type unit that in good working order won't pass the test.
Typically the units you are referring to are non-precision single pointer mechanical units. Many install these as steam backups and use the non-precision ones because the 2.25" precision ones are very expensive.
Actually here are the tolerances (hard to post colums, the second number is the tolerance):
Altitude (feet) Altitude Tolerance +/- ft.
-1000 20
0 20
500 20
1000* 20
1500 25
2000* 30
3000* 30
4000 35
6000 40
8000 60
10000* 80
12000 90
14000 100
16000 110
18000 120
20000* 130
22000 140
25000* 155
30000* 180
35000* 205
Brantel-
You are spot on "back ups" :D... In my mind, its a mini 2.25" precision alt (TSO'd) steam gauge at $1200.00 or an alternate gemini type device (non-TSO'd) sensitive altimeter. I've read several threads about MGL etc, etc. Not even coming close to tolerances. Just trying to budget for safety first (my butt).
Walt-
Thank you so much for the specs / tolerances. Not to be a pain but would you happen to have the reference material for the tolerences? I'd like to keep those as part of my personal reference Library.
Thanks again
