All EFIS systems have their engine sensors connected to a seperate module. I understand in most systems some proccesing occurs, then the sensor info is sent to the EFIS through usually an RS232 combus.
Not sure how the GRT system works as their 'engine sensor module' is also sold as a self contained engine monitor ( I have used their EIS 4000 for years). I was told that the engine out of limit parameters are programmed in the EIS module, although I also read that they are/can be programmed in the EFIS.
Can I connect the sensors to the EIS, forget any programming here and just program the limits into the EFIS.
Peter
Peter
