I have an RV7A with a TruTrak 380, driven by a Garmin 430w. It works fine on the ground, but cuts off in the air. I was told the TruTraks had issues with the solder boards, so i replaced the head unit with an xCruse. It still cuts off in flight after 10 to 15 seconds. Has anyone seen the problem, and have a solution? The local avionics shop is now telling me I need to replace the servos and possibly the wiring. I had had extensive conversations with Mid Continent and Bendix King with no solution. Thoughts?
