I have calibrated my WOT (Wide Open Throttle) True Airspeed at 116k however the G3X shows 113k. Is there a way to put a correction factor into the Garmin resulting in the TAS displaying 3k higher? I have a Garmin GAP 26 Pitot/AOA Probe.
This is most likely static position error. If it is, how can you be certain that it would be linear error and that correcting the high end point would result in the accuracy you are looking for?
I am not aware of a way to put an offset in the G3X but shoot an email to TeamX to be sure.
