Make sure you have the NMEA output enabled in the 396. This has worked many times and works well in all the '96 family of TruTrak's. Shouldn't be a problem, you just might have to tinker with some settings...that is of course assuming you've got it wired correctly. You do need the Garmin Data cable to get it (I'm assumin you did this already) hency my pointing towards some setups...
Stein
RV6's, Minneapolis
