Fearless
I am finishing up the wire runs in my wings before I rivet the bottom skins on permanently. I have the install kit for the Tru-Trak autopilot. While working on the modifications for the right wing aileron bellcrank brackets I found one of the bolts being short. The bolt in the kit was an AN3-23A but it looks to me that it needs to be at least an AN3-25A if not longer. Has anybody else ran into this already. I don't think you can fit anything longer than an AN3-25A and not hit the main spar trying to insert the bolt from the top skin. I tried searching the forum but couldn't readily find anything on this. I imagine a fellow could just remove the whole assembly and put the bolt in and then put the whole assembly back. This works fine with the skins off. I wouldn't want to do after the fact.
