Mustang said:
you could set up a nose high attitude with a little power on at low airpeed (consider the RV stall attitude is 23 degrees) and as your vertical speed would begin to go negative, this instrument would show a nose down indication. Even though your pitch attitude was 20 degrees nose up?!?!?!
I believe this analysis is incorrect. My understanding of this instrument is that in order to indicate a nose up or nose down attitude the plane must first pitch up or down. That is, the device senses pitch
ing rather than pitch itself. Once the device senses (and indicates) this motion, it then uses the vsi data to hold the indication. So, if you began pitching upward while descending, I believe the instrument would actually show no indication once the attitude stabilized. This is how the thing works to the best of my limited understanding. I can state for certain that pulling a vacuum on the static port of my ADI causes no change in indication.
Also, consider the exact same circumstances with a standard IFR instrument setup. You're nearing stall, mushing downward in IMC and staring at the attitude indicator. You're not listening, checking airspeed, vertical speed, or altitude. Assuming all this, you'll think you're climbing. I'm not saying this is better or worse, but the point is that you'll be misreading your situation. I think the bottom line is that no single indicator (yet) is able to give us all the data we need, so we have to scan.
I personally am only intending to use my ADI as a "bacon saver" if I ever unintentionally fly my bare-bones day-VFR fixed-pitch toy into clouds. I also like the idea that it gives me gps heading info and that the Trutrak folks will allow me to update it to an autopilot if I ever get this thing in the air and decide I wanna actually go somewhere.
Wow, talk like this makes me feel like it's actually gonna happen some day and I get all goose-bumpy
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
