Terry,
Just run them up the center tunnel. In my -9 I have one hole filled with the manual trim cable but was still able to run the AP wires through the same holes. Zip-tie pads with the two sided tape removed and glued to the floor every six inches with Goop Automotive Trim Adhesive holds everything in place and out of the way of the push tube.
